Hi guys, me again.
Thanks for all of the above - I've now hit the thanks button (hadn't seen it before!), I did appreciate it before though...great site!
Anyway the Wallstar - a little update;
- I had the local oil pro around the other day to service it. He set up the pressure & air settings using the FGA which was great. Burn now seems odourless and spot on. Cool.
- Dissapointingly, it's still locking out due to the air bubble.
Having read the questions above, some info;
- Bubble only forms when the boiler is running.
- I can actually see *tiny* bubbles being pulled in where the clear hose joins the NRV -i.e on the left of the picture below. (Is this likely the prob? - I tried to film but the bubbles are so small you can't see on a video).
- Each morning and evening at the moment, I manipulate the bubble through the burner and leave the tube full of oil. After an hour or two, the bubble is large, by morning, its the full length of the pipe and the burner has locked out.
- There is no tiger valve
- There is a fire-valve on the ground below the burner, but I can't see anything? It does have a little black plastic nozzle on the underside which can be clicked 'in' or 'out'. Not sure what this is?
I'd like to try some of the tests you guys have mentioned - like checked the operation of the NRV by disconnecting the pump-end of the clear hose, but how will I get oil back up to the pump one I've done that, will it pull well enough?
I'm sure I could change the seal washers in the connections to the fire valve and NRV, but again, could I get oil back into the pipe without some kind of pump or syinge?
Cheers very much as always
Tom
