Do you know how I can change the battery in the plip on my Peugeot 406?
And how it interfaces with the security keypad? ( Thats when it has a battery! )
On a lot of cars, when you remove the battery (either car or keyfob) the sync is lost between the two. Often all you need to do after replacing the battery is turn the ignition on and press the button on the keyfob within 10 seconds to resync the fob to car. Sometimes you need the drivers door open, other times you need the drivers door shut. Sometimes you need to press the button once, sometimes you need to hold the button down for up to 30 seconds. Other cars you turn on the ignition and press the lock/unlock button twice.
All seems to be a variation on a theme ..........
