    Dismiss Notice
Hyundai i20 Alternator drive belt
Discussion in 'Car Repairs / Maintenance' started by 233sqn, 21 Jun 2020.
  1. 233sqn
    233sqn
    8 May 2011
    49
    Thanks Received:
    Worcestershire
    Country:
    Hello all
    Time to replace the alternator serpentine drive belt on my son's Hyundai i20.
    I have had a quick look at it and I can't see any sort of adjuster to slacken or take up the belt tension. Is it just a case of removing the alternator top bolt and swinging the alternator clear?
    Excuse the ignorance!
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    22,860
    Thanks Received:
    4,451
    Northumberland
    Country:
    I think you'll find these have a spring loaded belt tensioner which is heaved against it's tension with a spanner on the central nut, allowing the old belt to be removed?
    These things need a fair bit of force to shift but you can usually see them 'bouncing' when the engine is running.
    John :)
  4. 233sqn
    233sqn
    8 May 2011
    49
    Thanks Received:
    Worcestershire
    Country:
    Thanks John.
    Do you know if a special tool is required or is it within the scope of an average home mechanic? I won't get to see the car for a few days, but there is a video on YouTube of a guy removing a belt by slackening the alternator and taking the tension out of the belt that way, but I think getting a new stiffer belt unstretched on would be a totally different proposition!
  5. Stivino
    Stivino
    11 Oct 2006
    3,250
    Thanks Received:
    327
    Midlothian
    Country:
    Is it the same as this?
  6. 233sqn
    233sqn
    8 May 2011
    49
    Thanks Received:
    Worcestershire
    Country:
    Yes it is the same as the video. Looks easy coming off but going back on with a new belt won't be that easy I'm sure.... and on the video the guy says he doesn't think this is the proper way to do it!
  7. Sponsored Links
  8. Burnerman
    Burnerman
    7 Feb 2008
    22,860
    Thanks Received:
    4,451
    Northumberland
    Country:
    When he heaves the alternator back into place he'll be fighting against the tensioner spring......personally I'd find the tensioner first, fit a spanner on the nut and heave it out of the way. It's usually a one person job.
    John :)
  9. Stivino
    Stivino
    11 Oct 2006
    3,250
    Thanks Received:
    327
    Midlothian
    Country:
    My daughter has that car car and was here yesterday (for father's day) but, she had gone before you posted otherwise I would have had a look because, I've done a bit of googlin' (no G) and found something interesting.
    This is her belt, yours could be the same. Her car is Hyundai i20 1200cc 2012 model.
    Read this;
    Car manufactures are bringing vehicle models into the market that are not equipped with a tensioning device. For these special accessory belt drive systems, Gates offers the ideal resonse with its Micro-V Stretch Fit Belt programme. Gates Stretch Fit Multi-Ribbed Belts are pre-tensioned over the pulleys, thus maintaining tension that is capable of efficient power transmission over a long period of time, yet low enough to allow foe easy installation and to prevent component failure.
    I found this, too.
  10. Burnerman
    Burnerman
    7 Feb 2008
    22,860
    Thanks Received:
    4,451
    Northumberland
    Country:
    https://www.motor-doctor.co.uk/tensioner/hyundai/i20
    This is what I fitted to a Kia C'eed a while ago.....unfortunately I don't know how old it was.
    Those stretch belts are the work of the devil....fine when the engine is on the bench but otherwise.....:eek:
    John :)
  11. 233sqn
    233sqn
    8 May 2011
    49
    Thanks Received:
    Worcestershire
    Country:
    Thanks for your replies. I had a look yesterday and i can't see any form of tensioner, just the crank pulley, water pump pulley, air con pump and alternator. So it looks like it uses a stretch belt. There are a few videos on line showing stretch belts being fitted on other cars and it seems they sometimes come with a tool to help ease the belt on..... but I'm not sure there is enough room to use one on an i20 in situ!
  12. Mottie
    Mottie
    27 Feb 2017
    16,290
    Thanks Received:
    1,754
    Essexshire
    Country:
    Stretch belts are normally fairly easy to fit - I’ve never used a tool ever and I just wind them on like a bike chain. You can buy tools that help guide them on to the pulley. The only exception is a Ford Focus with a twin crank pulley with two stretch belts. I only took it off to fit a power steering pump. It took me a couple of days of trying to fit one on and in the end I had to fork out a small fortune and buy a tool specifically for that engine. I have used it once more since when I had to fit an alternator to another car with the same engine so not too sore about it now! That Hyundai looks a piece of **** to do compared to most others. A 5 minute job!
    https://www.diynot.com/diy/threads/‘orrible-job.538455/#post-4547935
Loading...
Share This Page
