Long time lurker finally registered as I’ve got to ask. And before someone mentions the search feature, I’ve searched and searched on this topic on here (else where to) and the more I read (several times infact) the bemused by the whole thing I get, so I apologise in advance to the regulars who help mortals like me out.
I currently have an old Wyrex consumer unit (wired fuses) with one spare fuse point because I removed the monster oven cable a long time ago as I had no use for it. My immediate problem is I want to change how my external utility room is powered as currently it’s really scary (predates me). What I’m considering doing is using a 30amp wired fuse on the MCU, connecting 6mm TE to run about 12m under a suspended floor to the external brick wall, bury the cable in conduit for about 5m into the utility room and then up to a Volex RCD Garage Unit (Screwfix unit 40a 30mA RCD, 1x6a & 1x16a). From there I want to power a 5ft strip light and a 70w & 500w security lights (using either 1mm or 1.5mm TE) from the 6a feed. From the 16a (2.5mm TE) I would like to run a single double socket inside the utility room however I also want to run an additional 15 / 20m of 2.5mm TE down into the garden inside conduit mounted to a wall to power an IP56 double socket and an IP56 Switch / Fused spur to a low voltage lighting transformer.
The maximum wattage I will be using at any one time is around 3400, I calculated this based on what I could image running at any one time and then adding another 1/3 to that figure.
My obvious consideration is the ratings of the cable / fuses, and more importantly the 6mm of TE going underground. I have considered SWA however I already have the 6mm and the 5m underground run will be underneath concrete flags with no danger of human interference, I know this wouldn’t be an RCD protected cable because the MCU lacks anything like that but do I absolutely have to use SWA? And is there anything else I should consider as i've seem mentioned in a few of the posts on here about having an Earthing Spike as well?
Many thanks
Many thanks
