Hello All,
I have just moved into a house that has a seperate utility room with it's own fuse box (rewirable 5A fuse + 20A fuse) for a strip light and two double sockets, only ever used for a washing machine with a 1.2kw cycle.
This fuse box is wired back to the main consumer unit using 18m of 6mm t+e cable and connected to a 32A mcb cleverly labelled "cooker". All other mcb's on the consumer unit are in use.
The kitchen has an old gas cooker which I want to replace with a Whirlpool electric double oven (the hob will remain gas) rated at a total power consumption of 2kw.
My question is, can I put a junction box halfway along the existing 6mm cable and safely bring a supply from there 2m into the kitchen for the oven (via ccu with no socket)....or....do I need to run 9m of new dedicated 6mm cable for the oven (via ccu) with it's own protection, which will mean installing a new small consumer unit.
And finally, because this is a new appliance in the kitchen, is all of this notifiable before I start, which ever way it gets done?
Many thanks in advance for any advice or suggestions.
