I am in need of some practical advice, my house is a 1930's three bed semi.
The rafters sit on wall plates on the outside walls, 2' up from the wall the ceiling joists are connected so that the ceiling, which is lathe and plaster is fixed to the joists and then the underside of the rafters for the last 2'.
I have a supporting wall right through the middle of the house and the 4" x 2" joists sit on this wall. There are 9" x 3" purlins set in the side walls 18" above the joists. The ridge board is only 6'2" above the joist level, I would like to use this space for storage.
The only part of the floor that would really be walked on is 2' either side of the supporting wall. The confusion is arising from the fact that, all the posts I've read say if I want to walk in the loft I have to change the joists, because the joists do not sit on the wall plates, do I have to change the rafters as well.
I have seen on one site, a roof similar to mine where, the joists had 2" x 2" attached to the top, between the purlins and then hung from the purlins with 2" x 2" straps, this was done by a civil engineering company.
Will I need to fit a binder to the joists below the purlin, and could this binder be strapped to the purlin, say every 2 joists or does the binder need attaching to the outside and party walls. Any help please!!!
Cheers,
Colin
Cheers,
Colin
