I find it too hard to start my petrol mower - any advice?
18 Sep 2008
Dorset
There's nothing wrong with it. From new I couldn't start it. When a guy tries, no problem, but I'm just not strong enough and don't pull the rope hard enough or correctly. Choke's fine etc, as I say others can start it just not me. Are there any tricks or ways to make starting easier????
tried a gym? :wink:
or use it as an excuse to get the hubby to do it, or hire a hunky gardener...
This is the mower:-
Champion R484SP 46cm mower
 150cc petrol engine
 46cm Cutting width
 5 cutting height settings
 55L grass collection box
 Self propelled
It looks like a brigs and Stratton motor, they are very hard to start. I always take the air filter off and squirt a small amount of petrol into the carburettor. You should have got a Honda.
you'd think they could make these things "kick start".... then most people would be able to do it.. just jump on the thing..
happy - assuming choke & throttle are in correct starting positions try this method:
1. put your left foot (assumes you're right handed) on the machine below where the recoil starter cord emerges from the engine - this is to steady the machine.
2. using 2 hands gently pull the starter cord a couple of times (you'll feel a bit of resistance as the piston moves in the motor), this action is a bit like those guys in the movies trying to start old aeroplanes.
3. now you're ready to start - position steadying foot on the mower then quickly, in a two handed grip, whip the starter cord from low left across your body to high right in a fast action.
This technique was demonstrated to Mrs Symptoms by me and it works every time for her.
Does it have a primer? 4 pushes on the primer button and mine starts first time every time (Briggs and Stratton engine)
