Always on hand to help. Just check though, I'm not sure wilkos have yellow fittings so aren't approved for gas. Lidl, on the other hand, have them and are about 39p cheaper too! While your there pick up some of there generic brand washing up liquid. (34p iirc) and you can check for the leaks too.
Whole job should cost you no more than £2 and 20 minutes labour. Charge them about £220 and you're laughing.
If you want a proper job, as I like to do, then get some 1/2" nail in clips. On 12m 3 should be enough and it will reduce the sagging and improve the gas flow.
If it's a range cooker then consider using 3/4" hose for the first 2m. Should help massively. Hard to get in yellow though but they do acrylic paint in the craft section for next to nothing.
Jon
Jon
