i hear gushing water on acceleration pug 306
water level was low gushing started after topping up,could this be just air causing it?
Have you opened all the vent caps, some are just tyre valve caps, but some are small brass cap head screws, usually on the thermostat housing. There is also one where the heater pipes go through the bulkhead. Make sure that you get rid of all the air before you drive the car.
PS don't take the caps from the fuel rail near the injectors if it's a multi point petrol engine.
If the water level was low, then when you drive it and it gets hot, air will tend to be pushed out of the top of the rad into the expansion bottle. When it cools down it should suck water back in. So if you keep topping up the expansion bottle (remember to include antifreeze) it will tend to expel all air and fill itself with water. But if you are refilling, you can shorten the process by looking for a cap on the top of the rad and filling through there. It should be shown in your owners handbook or workshop manual. You do not normally have to open this cap, only when water level is low and it needs refilling. The usual top up is through the expansion bottle cap.
However, if you have a leak anywhere, not only will it continue to lose water, it will also suck in more air.
If water level was low then either you have been overheating quite badly or you have a leak. Look for damage to the front of the rad e.g. from stones.
Run the engine, stationary, over a clean dry surface and look for any drips or steam.
