I had the boiler fitted in July this year, and it's never worked properly.
When they first fired up the system, the F23 code kept kicking the flame out. Not technical speak I know, but I'm not sure of the correct terms.
The installers fiddled about inside the boiler and eventually, the fault code stopped showing and I was able to have some hot water. As it was July I didn't want CH of course, so I didn't expect my rads to get warm.
The day after they finished the install, my hubby and I went on holiday.
When we returned, the house was like an oven. All the rads upstairs were hot even though the control for the CH had been switched off.
I contacted the installers but they told me that it would take some time for the system to settle down and operate properly. I just had to put up with the hot rads or turn each of them off individually.
I used an Installer that I found through the Corgi website.
It's a very long story, but eventually, I had Vaillant send an Engineer to 'inspect' the installation. Several things he picked up on -
The 'flow and return pipes' were the wrong way round
Compression fittings should have been used to connect the pipework not soldered fittings
The gas inlet pressure only 15mbar when boiler operates at max recorded 20mbar at meter gas supply pipe restricted/undersized...
Today, the original installers returned to rectify the flow and return pipes.
They didn't do anything else.
The code F23 kept showing and they admitted they didn't know what they could do
and as they had another job to go onto they left...
Sorry about the length of this post, but I'm at my wits end now...I don't know where to turn
