I WONDER IF ANYONE CAN OFFER ANY SUGGESTIONS ON MY PROBLEM.
26 Jun 2004
London
I have an ASUS X553S running Windows 10. Quite a nice laptop with a 15" display.
It logs into my WiFi whenever I turn it on as set to.
But after a couple of hours it disengages the WiFi and if I try to manually reconnect it says "Unable to connect". But does not show any reason why.
However if I just restart the laptop it immediately logs in automatically as normal.
Does anyone have any suggestions for such an unusual fault?
I regularly scan it for viruses with AVG and sometimes Malwarebytes too.
Obtain a usb WiFi dongle for not much money and use it to get online, disabling the internal network card
Does the problem remain (it's not your laptop) or go away (could be your laptop)?
Are you by chance using BRSK as an ISP?
This is a common issue that we have, I'm told it's either the router or CGNAT that causes it.
If it's common to an ISP, it would point more toward an oddity with the router they have supplied, but I still recommend you test with an alternative network adapter per the suggestion above - they aren't expensive
