Does anyone know how to config ICQ to allow file tranfers??? I am running XP with it's firewalls in place. I hace selected the setting in ICQ for using a firewall - but it asks it u are using a proxy...and if so what type.......I'm lost!!!
always explain your abbreviations or people won't understand you
allow specific ports and block others
Eddie M said:Why do you say ICF is no good?
Igorian said:Some people don't even know how to turn it on/off, let alone configure it.
AdamW said:You can't rely entirely on hardware firewalls or the fact you are behind a router. I still get warnings that some script-kiddie has tried to scan me with his latest download from www.i-reckon-i-am-a-hacker.com.
Try explaining that to ban-all-sheds!Igorian said:AdamW said:You can't rely entirely on hardware firewalls or the fact you are behind a router. I still get warnings that some script-kiddie has tried to scan me with his latest download from www.i-reckon-i-am-a-hacker.com.
A hardware firewall, if set-up correctly, will provide better protection than a software one. Network Address Translation (NAT), although not primarily a firewall, provides firewall capabilities because it only allows traffic in if there is a matching outgoing request, or if you have used port forwarding. However, it will respond to pings and portscans, so an attacker will know you are there.
Most firewall software will block most incoming ports by default and leave outgoing ports open (some don't block them all). This can be a problem if a trojen server is already running because it can send packets which can then be replied to.
The latest way of getting stuff in is to attach a trojen object to a webpage together with a script. When you download the page into cache (ie, you let it in), the script can run and install the trojen, which starts a server and attempts to contact it's mummy. Hence the need to restrict scripts from running.
Just anothr game of cat & mouse really.
