hi, i have a problem with an ideal classic ff250. the boiler runs fine with casing off but when i put casing on and it seals the burner flames pulsate and die as if starved of oxygen. it then tries to relight and cuts out again within seconds. i have replaced air pressure switch but it still cuts out when i put casing back on and now unsure on what the problem is, has anyone else had this problem?
