Hi can anybody help before i call in a plumber. My Boiler fires up as normal but then cuts out (pilot still stays alight)...I then reduce the temperature on the thermostat until it fires up again...but then that cuts out (pilot still stays alight) and so until its basically off...would it be a problem with the thermostat?.....However when i remove the Probe attatched to the thermostat from its casing it fires up at a terrific and dangerous rate, and i obviously shut it down manually. could it be a problem within the casing the probe is fitting into?....
Any advice would be much appreciated
