EDIT I am aware that some sometimes a solenoid can be pulled in with a certain voltage and then held in by a ( much ) lower voltage.
So do you think a solenoid operates by voltage?
You will obviously be surprised to know that some do use an oscilloscope!
so you think its the gas valve then ? reading the manual is only a guide, but as i said before you need to know how and when the boiler works , i bet the op thinks because of your post that its the gas valve now , which in retrospect is he is now dealing with the main gas componentIt is not necessary to know how a boiler works to know how to verify the reason for low voltage on a solenoid coil.
you need to know the sequence , thats why you missed itHi, I have an Ideal HE30 which is displaying the L-F fault. I have measured only 110v dc at the gas valve(instead of 200v i believe) and there is no voltage going to the igniter module except for near the end of the sequence when 200v flashes up for about a second.
That's the thing these people don't realise just changing parts in their own boilers , idiots . Sitting back in their chair satisfied with their efforts when they could/probably have made it even more dangerous . There's no telling people sometimesI take it you removed the burner and checked insulation and removed and upgraded the retention pins per Corgi Bulletin from about 8 years ago?
Then on putting boiler back you checked FSD, inlet dynamic pressure, gas rate and did a Flue gas analysis in line with anyone taking off combustion cover.
