Ideal ICOS HE15 - continuous fan running
5 Jul 2007
Just got this boiler installed and noted it contains its own pump and a fan assisted flue. The problem is when the boiler cuts out and stops burning gas i.e. standby mode, the fan keeps running. Both the fan and pump together generate quite a bit of noise. Is this normal? Can or should the fan be switched off when not burning gas? Is it possible to program it to shutdown when not required?
1 Jul 2007
Hertfordshire & London
The fan and pump do overun, a few seconds and a few minutes respecotviely.
Otherwise you have a PCB fault - call 'em in and make them suffer!
10 May 2006
Merseyside
respecotviely.
jesus dan how many have you had tonight? :D Thats got to be the worst attempt at spelling I've seen on here, you started it so well too :LOL:
5 Jul 2007
so i presume there is no technical reason for the fan to continue running ? could the pcb be realistically faulty straight after installation?
28 Mar 2006
Hedge End Hants
shouldn't be noisy they are normally reasonably quiet when running and the pump isn't part of the boiler is it a new one? is it bled properly? also although not relevant on the 12 and 15 the larger 19 and 22 Kw versions require 28mm pipework (got caught on that when i fitted the first 19Kw Evo)
5 Jul 2007
it has an integrated pump, i took off the covers and verified what the manual diagram indicated. Not sure if it is bled properly - will check. by the way the whole unit makes the same amount of noise regardless of whether the unit is burning gas or not !
23 Feb 2007
Norfolk
Only the system boiler versions have pump over run built in. The fan will keep going for a few minutes to clear all poc from heat exchanger. If a system boiler the pump could run on for about 6 mins. Didn't think the HE15 was a system boiler though :rolleyes:
Perhaps its been wired up wrong with the permanent live and switched live transposed.
5 Jul 2007
its a HE15, non-system type boiler. it turns out the fan does spin down after unit goes to standby. the noise is from the integrated pump in the unit continuously circulating HW through the pipes. Pity it is integrated into the unit as the pump is hidden away in some other houses in hot presses etc and they are usually very quiet, even up close.
28 Mar 2006
Hedge End Hants
there are two versions of ideal and 1 version of evo HE15
only 1 of the ideal versions is a system boiler with internal pump the other two are heat only boilers!
1 Jul 2007
Takes me back to the CBi days when the system boiler version was actually a phecking CDi without the combi fittings.
What an embarassing morning that was :(
28 Mar 2006
Hedge End Hants
just like a Vaillant Ecotec 600 series! which is a 800 series without the water side :LOL:
vvvvvvvv recently found out they make a heat only boiler!! 400's oh well live and learn :LOL:
1 Jul 2007
Yeah but no phecker at my merchants OR Worcester bothered to tell me when I phoned up to ask. I fitted a lot of CBi's 'cos of their size and were better than Suprima's.
