Ideal ICOS HE15 Error Codes LE and LF
23 Mar 2010
Hi All, wonder if you could help me please?
I recently purchased a house with an Ideal ICOS HE15 in, a couple of years old. For the last few months I've had LE and LF error codes now and again - sometimes a few days in a row and sometimes every few weeks so no pattern! I just hit reset and off it goes with no problem until next time it hits, days or weeks after.
Would anyone be able to suggest how to fix it or if I need contact someone to have a look?
Thanks in advance!
David
IIRC LE and LF are ignition probs so will need a RGI to sort - could be wrong about the codes so you need to look in "the book".
These are the fault codes for pcb and flame detection errors. Might be cheaper getting a fixed price repair if it continues.
LE can also be a faulty overheat stat,on the Icos the oh stat is up near the top of the boiler,and if the connectors above leak water/crud can run down to the stat.
LF is flame detection,as already mentioned.
Thanks in advance!
David
Try unblocking the condense trap if it is blocked it will prevent the boiler firing
Diyers should not remove the condense trap, as refitting incorrectly will cause POC's(products of combustion) to escape from the boiler into the room.
I seem to remember there are two types of LF indication ( perhaps LF. ? ).
One relates to failure to ignite and the other flame failure after ignition. The difference would be relevant to the engineer doing the repair.
A common cause of this fault is an inadequate gas supply or a sticking meter governor.
Regardless you need an engineer.
Tony
Run it until it breaks down then change it. Or take out a repair
contract.
These boilers are awful.
Tony is right as .(dot ) after each code is different to normal code. LE can be board but also electrical supply fault or poor earth. Can also be open circuit overheat stat or overheated. And now for the interesting one for all you Isar/ ices lovers.
Ready, if the boiler detects 3 overheats in the one on period then it will cut the power to the gas valve relay so next time it try's to light you get an LF! Could be dodgy overheat stat causing the boiler to do this giving both fault codes.
Thanks in advance!
David
Hi, Ive read your quote and I've had the same LF error/fault aswell as Hb error. My boiler is a Combination. So what I did was, looked on Google Image and typed the traps for this HE15 in and what you know . .Up comes some pictures/images of the HE15 boiler. I then removed the trap than found that it was blocked with dirt. Cleaned it, placed the pipe back. Shuddering noise gone. So, ive attached a link to see where to look.
http://idealheating.com/homeowner/frozen-condensate-pipe.php
Gook Luck
