Hello
A week ago our boiler started making a loud vibrating noise which you could literally feel from the other side of the kitchen! Thursday evening last week we got an LF error code, after calling Ideal they told me that this is a lockdown error and that it meant that the condense line was probably blocked and to call an engineer out.
Today I had a gas engineer come to my house - he opened the gasket, cleared the water and dirt in there, he also removed and cleaned a plastic trap at the base of the boiler. When he turned the boiler back on the LF code turned to c which is what it is on at the moment. However, as I mentioned above, before our boiler went to LF status it was making a loud noise (very hard to explain, almost sounds like a car with a power pipe). It took about half an hour for this noise to start up again after he left - this time though we aren't getting an error code! When the boiler is running it makes this noise (when the burner light is on continuously). What could this noise be and how can I rectify it? If I leave the boiler on will it damage any other part of the boiler?
After spending close to £300.00 today I don’t know what I should do next.
Please help?!?!? Any suggestions would be hugely appreciated.
