Ideal icos m3080 failing with ' - ' as error code
1 Jul 2006
Edinburgh
I see various posts about Ideal boilers but not for this, can anyone help?
Ideal m3080 has intermittent 'fault' when on timer - after coming on, green burner light on and error message reads ' - ' rather than any of letter codes, boiler no generating hot water or heating.
When turned on manually (via timer control) appears to work OK.
Previously turning boiler off, then on, reset it and it'd then work OK. Recently failed with PCB error - PCB has been replaced. Same intermittent 'fault' again when used with timer.
Ta for the reply - short answer is, I don't know.
Not being a professional can I ask a stupid question..
Would it be obvious if the vent had a leak? would you see it when, say, the PCB was being replaced? (if you weren't really looking for it)
Could be it isn't leaking leaking from the AAV. You might find it hasn't got one :wink:
My icos M3080 boiler packed up (typically) on Jan 1st 2007 and having followed all the fault-tree analysis, I wound up replacing the PCB (Primary Control). Ever since, it has "flatlined" with regular monotony (normally in the winter of course) usually in the night or when away for a couple of days, to please me returning to a cold house..... Always cured (no not cured at all actually - always re-set) after switching off & on at the rocker switch. Come back this time & the illuminating LED on the rocker is on, but otherwise appears stone dead. Please, not a third PCB at £212???
