I see various posts about Ideal boilers but not for this, can anyone help?
Ideal m3080 has intermittent 'fault' when on timer - after coming on, green burner light on and error message reads ' - ' rather than any of letter codes, boiler no generating hot water or heating.
When turned on manually (via timer control) appears to work OK.
Previously turning boiler off, then on, reset it and it'd then work OK. Recently failed with PCB error - PCB has been replaced. Same intermittent 'fault' again when used with timer.
