Ideal isar combi problem
11 Sep 2007
Sheffield
Hi have a Ideal isar m30100 combi boiler,
Have L.F flame tetection,flashing on user contol.
Instructions say replace flame tectection electode,this I did and worked great for about 5 wks,then flashing returned again.
Befor boiler goes out boiler casing vibrates as though flu gasping for air
Would appreciate any comments.
Reguards
baz
Could be the fan then if noisy and vibtaring.
L : F just means the boiler has not detected a flame withing the allotted time span.
Could be something simple like the working pressure on your meter govenor is too low to ignite the gas in the boiler.
Can govenor be ajusted or must I replace,cheers
Only NG can come out and check this and replace if needed. They come out free to do this.
This fellow does not want to call a CORGI !
It sounds as if the mixture is too weak.
Needs an FGA check to confirm.
