Ideal Isar HE24 always heating
6 Oct 2014
Durham
Hi folks, I appreciate that I have been saddled with a notoriously failure ridden boiler.
I replaced the overheated and bent PCB a while ago when the boiler went dead.
For a while, the boiler behaved.
Now though, the only way to stop the boiler is to switch it off altogether!
As it runs on the timer, it constantly heats the house, even when it is programmed not to!
Trust me, it is not miss-programmed. I've checked, my wife has checked and our 14 year old has made sure we aren't senile!
I understand it will fire up a t code, which warms the exchanger plate (fine so far). But in the middle of the night, the radiators get red hot, despite the programmer not being active.
I've fitted a new room stat and rolled it to zero. Still the house roasts and the bills rise!!!
The programmer is a Plumb Center basic jobby (less to go wrong) and I am tempted to swap if for a Drayton lifestyle LP711 electronic timeswitch.
However, could the problem be an internal valve sticking open? Or something else?
Please help.
Ta.
Sounds like it could be a faulty diverter and preheat passing to rads? Turn boiler off for a while to cool, then put on and feel the left most pipe under boiler, does it get warm?
Diverter valve then. There are a couple of different ones depending on how old/new your boiler is which are not interchangeable.
Thank you both for your time/ opinions.
Serial number:
Is it a difficult job to replace one? I've rebuilt engines and diesel injection pumps, but central heating is new to me.
Try £50 plus just for cartridge and hope heads not faulty aswell! Check this link out has all variants of diverter valve
Right then,
I have a grey head actuator and I have removed it from the neck that holds the valve.
The Actuator pin on the valve is really stiff. I presume I need a new cartridge valve.
How do I test the motorised head?
Shall I fire up the heating, switch between DHW and heating to see if the cam turns?
If spindle is stiff then it'll need changing. Honeywell one, very easy to change. The tool to remove it comes with the kit. Head is very rarely faulty unless it's got wet.
