Came home last night to find that I had no hot water! The boiler is 5 years old and this isn't the first time it has broken down.
Last year it wouldn't give me hot water but the heating was working. It would make noises when I turned the water on as if it was trying to light but couldn't.
The front display showed a horizontal line with a dot in the corner of which ideal advised that was fault so replaced it. Still didn't work! Sent that back and replaced the PCB and it's worked since (the front display still shows this line and dot though).
Now it won't give either hot water or work with the heating. When I turn the water on it makes no noise as if attempting to light. All I can hear is a faint clicking noise that I have found is coming from the front display.
The pressure is above 1 bar and there is a possibility that the front unit displays some letters for fault codes. However its faint and only does it ever so often so I can't be sure, but if I had to guess it was a L and then at some point an E.
Also there is no sign of life from the burner light on the display and I have held the reset button for longer than 3 seconds.
Can anyone help before I throw this thing out the window!
Thanks!
Thanks!
