Boiler has developed this fault over the summer. Worked fine when CHS was on back in the Spring.
Pressure is 1.5
All valves are open - pointing up
Set to winter mode.
Boiler fires up but after a couple of minutes stop and displays pump overrun. No error messages.
Immediately under the boiler the CHS Return heats up before Flow.
Pump is running, I can feel it buzzing, and when bleed valve at front removed shows spindle going around.
Any ideas?
Pressure is 1.5
Set to winter mode.
Any ideas?
