I have posted before but cant find it, things have moved on but the problem still keeps coming. The engineer is stumped.
It has been serviced, gas valve changed, Igniter changed, flame detection sensor cleaned (looks very clean)
Condensing pipe def not blocked. It will fire up and run but does seem to go off and call pretty frequently which i understand is normal, but its when it calls it tends to take a few calls or goes into F 2 code (which is the same as L2)
The pressures and mix was all tested during the service and were found to be good. I am wondering if any one has any further ideas as I am not keen to keep calling the engineer when he is stumped as the next thing will be to change something else and see what happens.
Whats weird every time something has been done, seems to run a little better but then F2 appears and begins to be more frequent.
He has also checked the fan and flue for any blockage.
Not to much left inside the thing. Wishing i never had an Ideal boiler apparently Worcester or Vaillant are the best.
Comments from thoughts or experience with this or similar and appreciated
