Hi all,
Hope you can help!
I have an Ideal mini c28 Combi boiler
Have been doing a bit of work recently; I have changed the diaphragm in the diverter valve (split) and cleaned out DHW heat exchanger (wow the muck that came out of that!!).
So it already works 50 times better than before. However, I still get a intermittent problem - it might be easier if I bullet points things that may help diagnose...
Basically sometimes it will not light - the fan goes makes all the noises but no luck and soon after (if I switch the correct tabs) I get the led flashing codes = Lack of burner ignition (no ignition signal from
the full seqence ignition device)..
- once this happens, it will no longer light. DHW of CH.
- If I turn it off at the plug and leave it for a good few hours, it will light first time,
- If I turn it off and back on in within a a minute or so, it will not.
Do you think it could be the Ignition PCB? for 34 quid I can get a new (ebay recon) one and it would be just a straight swap.
Anyone have any ideas?
Many thanks
Hope you can help!
Many thanks
