hi guys hoping you could advise
i have an ideal mini c24 boiler, the pressure gauge which also includes the temp gauge the needle does not rise,
when the hot water is running or if the central heating is on the temp gauge needle does not rise to the temp it should be it stays at 0 degrees
a week ago it was working fine but now the needle does not show what the temp is - no movement
the boiler pressure gauge needle works
any ideas as to what the fault could be?
