Hi folks,
I have an Ideal Response 120 combi boiler (fitted with the additional IDEAL electronic timer) and after 6 or so years of trouble-free service it blew the fuse on it's mains spur late last night, thus tripping the RCD for the whole house. Unfortunately I didn't pinpoint the problem to the boiler until this morning when the heating didn't come on as normal. When I replaced the fuse and reset the clock on the timer I was then able to fire it up again and it started to heat as normal.
However, after just 10-15mins the fuse blew again, tripping the house RCD. When I tried another new fuse, this one blew as soon as it made contact. I guess the difference with that one was that it was replaced immediately and the system was already up to temperature and was demanding central heating as the fuse was replaced.
Having searched the internet this morning it appears that this particular boiler is a bit of a dud and that I'm lucky that it's lasted so long without problems. However, most common faults are leaking heat exchangers etc and at the moment that doesn't seem to be the case.
I'm going to go home and have another look at it during lunchtime (this time going through the MI), but if anyone has any helpful ideas as to why it's suddenly started to blow the fuse (and why it seems to be capable of working normally for at least a short space of time) they would be very much appreciated.
Cheers,
Dan
Cheers,
Dan
