Ideal Response 120 does light but for 5 seconds only...
20 Mar 2008
Cheshire
and then it goes off, leaving led2 on PCB 37lit. Before this to happen it ignites and heat the tap water for 5 to 10 seconds then the water turns into cold again. Well, this is less then IDEAL and I would be grateful for any helpful RESPONSE.
Call out Ideal on a fixed price call. They made this cr*p let them fix it.
A lot of engineers won't even come out to this boiler, myself included.
Quite possibly heat exchanger leaking.
Prepare yourself for a new boiler :cry:
Thank you to both of you for your quick answer, even if they are rather disappointing (nevertheless not fully unexpected :( )
Thanks again.
I'v only got a year's experience so I wouldn't put any money on it (unless its not mine :D ); It seems to me that it's a flame rectification problem; new rectification electrode req'd or worse case, PCB shot!
Hope this helps
Hope this helps
Unfortunately your lack of experience shows in this case!
You are right thats its a flame detection problem but almost certainly its as a result of water leaking on that model.
New boiler time!
Tony
Well it could be that the wire's fallen off the detection electrode!
BUt I declared yet another Response dead due to leaking hex, yesterday. An 80, for a change.
[/quote]
New boiler time!
Tony[/quote]
I called out Ideal I hope they can repair their cr*p! Thank you
It might have been cheaper to call an independent!
Does anyone know what Ideal charge when its a leaking HE and thus irrepairable?
Tony
~Ideal told me it would be 175+VAT if anything but the HE is wrong, and an extra 180 if it was the HE. It is still cheaper than a new one, I think.
