ideal response 120 problem
19 Dec 2012
Cheshire
hi there.
have a problem, not getting any hot water or heating.
the boiler has power and when you run the hot tap or switch the heating on the tank gets hot but the burner light does not come nor does any hot water come trough the tap ?
pressure is fine.
is it possible that there is a blockage somewhere ?
thanks in advance.
how can anything get hot if its not firing up :unsure:
Sounds like a job for a professional anyway. Recommend you chuck it in a skip tbh, not many of these left for very good reason.
it heats up then cuts out like it overheats as the hot water has no where to go ?
seems like a blockage but dont know where to look
That isn't the tank.,
That is the main heat exchanger and you should be poking around in there - ESPECIALLY with the power on.
You need a professional.
Heating pressure is too high as well.
Oh what fond memories,I haven't seen that view for 18 months since I left Warmsure.
I dont think that anything of that power will fit in that cupboard!
Tony
