ideal w2000 bolier not firing
24 Jan 2009
Cardiff
the pilot is lit; but the boiler won't fire and there is no hot water or central heating despite both thermostat being on max; the boiler switch is on the max...... the only thing i had done was to reduce the water temp thermostat on the hot water tank couple of days ago. any ideas ?
thank you
Make sure all 3 stats are as you said.......
1) Boiler stat set to Max 2) Room-Stat up Hi ? 3) Cyl Stat above 60deg ?
Could be a few things - Pump, Div Valve or Gas Valve
Are pipes to CHB Hot or cold - or one hot one cold ?
Good Luck
all thermostats on high .... the boiler does not fire so no hot pipes anywhere !!
if you have a multimeter and know how to use it, check that you have 240v at the L connection in boiler, if you have 240 then its a boiler problem, if not then its an external control fault.
