I just knew this would get complicated...
What are you using crimp connectors for on 240v ?
Bit of background:
I have a 300L thermal store fed by a solar panel coil, wood burner and two immersions - a low one on a timer, for heating up the entire store overnight on E7, and a high one on a timed button, which was originally meant for an hour of day time topping up, if the store heat were to get exhausted. The store runs radiators and hot water.
Anyway, during the summer, when the radiators are not used, it makes little sense heating up the whole store with the lower immersion, so a method of switching to the high immersion is needed, to ensure that just the upper part of the store is heated overnight, leaving the lower part cool, so it can make the best use of solar as a pre-heat for the next day, and saving a few units of electricity.
The sensible solution is a relay with a switch, so I can switch the power going to the lower immersion to the upper one through the summer.
The crimps are for connecting the relay to the immersion cables, inside a surface mounted junction box. I had something supplied for the job, pre-wired, a couple of years ago, but it was never installed, and now I'm looking at it, and I am anxious that the supplier has used rubber cable and not PVC heat resistant cable. And actually, now I look at it again, the connectors used are actually colour coded - there's red and blue connectors (which do not correspond to live and neutral - the red connectors have been used on the switch connections, and blue on all the immersion circuits). I'm also not convinced by the solution used to hold the cables in the box - it doesn't look that secure, to me. And, as if that wasn't enough complication, I can see a much tidier way of doing the job than the one that was suggested originally...
I don't especially want to tackle it myself, but I do want to fully understand what is right and what is wrong...
Is it OK for me to talk this through in a bit more detail?
Wiring diagram drawn by small child...
http://f.imagehost.org/0484/wiring.jpg
