hi forum
I have a perplexing issue with a combi boiler.
It works fine if it hasnt been comissioned (ie is 'cold').
it also works fine when 'warm', ie has been comissioned for less than 2 minutes hot water draw.
but if an extended draw of hot water has just finished, then for 10-15 afterwards it will not spark up.
the 2ndary loop is about 6m of 22m pipe, as the rads have been removed from the house.
could it be an issue with the expansion incorrect air pressure to cope with the reduced circuit?
thanks b.
thanks b.
