I have a greenstar i the heating works fine and the hot water is the problem the ignition flame fires to heat the stored water in the tank within and when I run hot water once the stored water temp has dropped the ignition flame tried to ignite and but will not stay ignited after a couple of attempts it will lock out code 227 the boiler indicates water is running pressure is at 1- 1.5 condence trap has been cleaned and connecting pipework checked for blockage any help would be much appreciated
