Immersion heater replacement
23 Jun 2004
I am about to replace a furred up immersion heater. It makes all the noises of a furred up kettle.
Is there anything I should be aware of or wary of before starting this (besides draining the tank.) ?
24 Jul 2003
London
Lots can always go wrong in plumbing! Read all you can first - search this site.
16 Sep 2003
If it's a top fitting heater, you don't need to drain the tank, there again, if your heater is scaled up, you may need to drain the tank and then use a wet vac to suck the scale out of the bottom of the tank.
