Good Evening to all.
I need to replace the immersion heater in my copper tank.
The job does not really present a great problem. However, I have one specific problem.
The drain plug for the copper tank is inaccessible - the tank is in a hot press and the drain plug is located at the back. I cannot get at it.
If I turn off the cold water supply to the tank and turn on all the hot water taps in the house, would it be possible to siphon off some water from the tank when I remove the immersion element ? Or, would I have a flood ?
Any suggestion would be most welcome
Many thanks,
Jimmy
Many thanks,
Jimmy
