Immersion heater turning on randomly
Any idea how to work the cost of electric v oil?
You will need to ask someone who uses oil, for typical costs per Kwh for oil.
But this suggests 4.8p per Kwh in 2020, which is very close to the 5p you pay per Kwh for electric during the night. If oil has gone up, then it might be worth setting your immersion heater to run for the entire off-peak supply period, then completely off during peak.
Anything that can be done and its really quite loud? Would it help not having that pump on which puts the hot water around?
I would guess at the room warming up causing the expansion. Could you lower the head on a night to drain it, then raise it back up.
No its a fixed one, unfortunately.
That's where the question around why the shower pressure is lower in the top verses the side one I thought might be size of pipe
EDIT - will need to run the hot water on a cycle (morning/evening) else the towel radiators are on all the time (they don't have thermostat valves)
the cylinder is so big that morning and evening will be plenty.
If, as likely, the towel rails are on the cylinder heating circuit, the cylinder will turn off the circuit when the cylinder reaches its target temperature and stops demanding heat. If the CH is also not demanding heat, the boiler will then turn off. Try it.
I find this very handy because in my house, it means the rail warms up shortly after you start running a bath.
I'll give it a go!
