- Joined
- 8 Aug 2024
- Messages
- 1
- Reaction score
- 0
- Country
Hello all,
I have recently moved into a new property, which has an electric immersion water heater. We were left no instructions on how to use it, and the landlord only seems to be guessing on what switch does what!
There is a switch that says ‘Water heater’ in the kitchen, which lights up when you press it on. This controls another switch that says ‘Water heater’ by the water tank, the switch stays off but the light turns on. There is another switch below it the also says ‘Water heater’. I think this was on when we moved in, and you can switch its light off and on by flicking the switch itself, off and on.
So far, with both switches on, we had hot water a couple of hours after switching it on. The landlord said something about overnight and boost, but then to leave the top switch (controlled in the kitchen), on all the time. From it heating the water in the day rapidly yesterday, surely this means the water will be continually heated and be very expensive. I thought one switch would be the overnight setting so we would hot water, heated by cheaper off-peak electricity, in the morning.
Any help would be greatly appreciated!
Thanks,
Jake
Thanks,
Jake
