P
pna
The Monty Hall scenario is quite simple, and the odds can easily be followed......
1) Their are 3 doors, your chance of picking the correct door with your first choice is...1 in 3 Therefore you will only win the car 33 times out of 99 attempts, if you stick with your original choice
( if you think carefully about the above sentence, its all you need to know )
2) So what is the advantage in switching, well we already know that in 2 out of 3 Attempts, the car will be behind the other 2 doors, that you did not choose.
Monty now removes the goat for you........![]()
Thus the remaining door contains the car 66 times out of 99.
Its a must switch, thanks to Monty removing the goat
Point 1 is correct. At that time there are 3 boxes.
Point 2 ('thus the remaining door contains the car 66 times out of 99') is not correct. This is because each 'probability event' is separate, and you have to calculate the odds separately each time. Just because you have tossed a coin 100 times previously does not influence the next throw, and so it is with this scenario.
You might think you have learnt something from seeing the goat, but you havn't, because you ALWAYS see a goat, no matter whether you picked the car or the other goat on your first choice. There are only 2 boxes left - its a straight 50:50. Wondering if you should swap makes for good TV though...
