Imperfections on new plaster
13 Dec 2009
Cumbria
I have just plastered my kitchen and have a couple of water mark indentations that require filling. I have tried polyfilla which just wont adhere to the plaster, what am i doing wrong? This is my first plastering job. I tried the the polyfilla on freshly dried plaster do i have to wait a certain amount of time or prime the plaster somehow? Any help would be appreciated.
Well done Bainzy for doing your first plastering job,, your kitchen. It's not un-common to get the odd blemish here and there. As long as you're happy with the overall job, that's the main thing,,, you'll learn from it. It's not advisable to use any type of filler onto bare/new plaster, as you've found out,,, because the suction is high, and any filler wont stick, as it dries out too quick. The best thing to do, is give the wall a mist coat of thinned down "matt emulsion", then give it another when it's dried. The mist coat will highlight any small imperfections, and it is simple to fill them up, because the plaster has now been sealed. I would use a small amount "ready mix joint finish" to fill any blemishes, and then sand it down gently when it's dried out.
certainly not unusual when you've done it rc, :wink:
The best thing to do, is give the wall a mist coat of "matt emulsion", then give it another when it's dried. The mist coat will highlight any small imperfections, and it is simple to fill them up, because the plaster has now been sealed. I would use a small amount ready mix joint finish to fill any blemishes, and then sand it down gently when it's dried out.
Oh yes indeedy
Oh yes indeedy
:wink: :lol:
I had a feeling it would be something to do with suction but i am still learning so thanks for the advice. I will try your advice and see how it goes.
