Important information Preparing for a power cut.
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
Prepare for a power cut
Here are some things you can do to prepare for a power cut:
Oh, come on, do they really need to tell people to keep a torch and batteries, etc? But it did prompt me to make a lead so I can use a 12 volt battery to run lights, but how often do we get power cuts? So the web link here now the web does tell you to check it has not tripped in the house. But the leaflet through the door does not even say to do that.
So what do you do to prepare?
And a twin spot in the living room and each bedroom.......(just kidding)
Here are some things you can do to prepare for a power cut: ... Oh, come on, do they really need to tell people to keep a torch and batteries, etc?
In the case of some people, they probably do need to tell them!
.... but how often do we get power cuts?
Quite so. In my case it's decades since we suffered a power cut of appreciable duration. However, it's surely you who is always going on about this tiny 'risk', particularly in relation to freezers, isn't it :-)
However, it's surely you who is always going on about this tiny 'risk', particularly in relation to freezers, isn't it :)
Yes, OK, but I note the pamphlet does not talk about freezers. It gives the phone number 105, talks about having a torch and batteries, tells you to charge phone and power packs, and to have extra blankets and warm clothes ready.
The advice I would be giving is to have a non-cordless phone so it will still work in a power cut, or a mobile phone, I would warn internet phones will stop working. One needs a copper connected phone where possible.
I have a rather old jump start set, which like this one
has a 13 amp outlet with 300 watt capability, so I can plug in a route r, or cordless phone base.
I tried to replace it with a modern one,
but it is rather useless as a back-up, it does have a built-in torch, but no 230 volt outlet. And no cigarette socket, so can't use all the emergency lights one has for the car in the house.
These
are likely the best emergency torch, it will not last long, but does auto light. It talks about priority services register, OK, I am over 60, have a disability, but what are they saying? Are they really going to get my power on before next door? Next door with a small child and no solar panel or battery is likely to need power more than me.
I note nothing about candles, suppose they are considered dangerous, I know in the Falklands many a house fire due to candle use. As to the tilley lamp or modern types,
again nothing. I did have one like the centre one, and it now does not work, as the batteries leaked, would that have not been good advice, don't leave batteries inside the lamp?
Likely the Paraffin lamp is one of the best ideas, as my central heating oil is 28 sec, so near enough Paraffin. And they help keep one warm as well.
As to noting where there is a pay phone, I did do that, and when I came to use it found the box had a defibrillator in it, and no phone, but you needed to phone to release it, so could have not used it even if I wanted, and the other phone box I found was a book exchange, if you need a phone you have to find someone with one stuck to their ear.
I do have a handy, tri-band, but I have never heard anyone, but the local steam heritage railway use radios, years gone by the railway would have had phones, not any more.
Police station closed, and police house sold off, the most likely place to get help is the pub. The church no longer has open fires, so would be rather cold, but the pub does. The railway carriages are steam heated, so they could be used.
But the leaflet was next to useless, it does say
Need an interpreter? We offer a free service in over 100 languages, call 0330 10 10 444.
But unless you can read English or Welsh you would not know what it said.
It is from Spencer energy networks, some mothers do have them!
How does one find a torch in total darkness ?
We have light from the street lights
Yes, OK, my emergency touch does light automatic with a power cut. But yes, in a power cut no street lights, and one hopes you have a mobile phone to find the first torch with.
I had enough problems finding the light switch when I fell asleep watching TV and TV timed out, and it had got dark, now I use a smart light switch that turns on ½ hour before dusk.
And at home I put mobile on charge, so can't use that until I can find it.
For those with solar+batt, would you pay extra to have an EPS installed? Most inverters have EPS capability, but you need to reroute some circuits and have a manual or automated switchover. Probably not DIYable such a thing. I've had three powercuts since I moved into the area, but two out of three have been during the day while nobody was at home and only lasted 10 minutes. The third one was during evenings around 6pm, but also only lasted 5 mins so not really needed to have anything prepared ready. Mind you I live fairly central so expect any outtage to be resolved quickly.
But it would be a nice to have given that I have batteries and it seems a bit silly to be unable to take advantage this if there were any longer lasting cuts.
Yes, I did, but it only supplies freezers and central heating. I did consider lights, but many of the lights need the router and hubs running to turn them on/off, and also 48 watt just in the living room, and with a power cut, 6 watts would be ample.
Once into the power cut, then one can get what one needs, but it is the first 2 minutes where one sits and considers where the cat's toys may be.
I think I gave up smoking around 1978, when a packet of 20 king-size No 6 went to 50p a packet. So I no longer carry matches or a lighter, my wife has a dragon on the fire place which takes smelly things that puff smoke out and there are matches around it to light them up. But finding them in the dark without knocking plants off the fire place is something else.
And as to pack of Prices candles, not a clue where they are.
I charge my phone, when my phone needs charging, so it's state of charge would be entirely random, when a random power-cut event happened. I don't have any USB power-packs either, but all is not lost....
I could plug the phone into my mobility scooter, which has a USB charge port, or the car, or the caravan's USB.
We recently topped up our emergency stock of candles, which was last topped up in the 80's, stashed on the left side of the airing cupboard - nowt much wrong with candles, if used with proper care - stuck on a saucer, placed on a fireproof surface. The torches are fine, for short term use, just to find our way to the candles, and we keep the torches always in the same places - one in the kitchen, one at the top of the stairs, and a third in a drawer in the caravan.
That's probably because (a) there's not much one can do (other than expensive batteries/inverters or a genny) to 'prepare' for the possible effects of a power cut on freezers, (b) that they consider it very unlikely that many people will suffer power cuts so prolonged as to be an issue for freezers (deliberate 'planned' power cuts' presumably are limited in duration for this sort of reason), and (c) that (the extremely small risk of) loss of freezer contents is not the end of the world, and may be covered by insurance, anyway.
... not for much longer, it seems.
, or a mobile phone ....
As recently pointed out, it seems that most of the mobile phone infrastructure ('masts' etc.) has no power back-up.
My power tool range is Milwaukee, I have many batteries and M18 light/torches, also a charger for the van. I will never be with out light.
Andy
