    Dismiss Notice
In Hot Water.......
Discussion in 'Plumbing and Central Heating' started by Martin Cannon, 22 Oct 2019.
  1. Martin Cannon
    Martin Cannon
    22 Oct 2019
    4
    Thanks Received:
    Country:
    Has any one out there got any ideas why my boiler is heating up my hot water the pump remains on the boiler fires up every short while, then of mean while the pump is merrily running away and by the end of the day the water is really very HOT. I have just fitted a Hive Active 2, double checked and triple checked the wiring positions as per listed on the Wiring Centre. The central heating is working fine. Any Help will be Gratefully Received.
    Martin
  2. Sponsored Links
  3. ianmcd
    ianmcd
    15 Aug 2010
    20,625
    Thanks Received:
    8,021
    Lanarkshire
    Country:
    we will need a lot more information, boiler make and model, S or Y plan? do you have a cyl stat ?
    • Thanks Thanks x 1
  4. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    Have you actually measured the temperature of the water at the tap?
    • Thanks Thanks x 1
  5. ericmark
    ericmark
    27 Jan 2008
    17,466
    Thanks Received:
    1,617
    Llanfair Caereinion, Nr Welshpool
    Country:
    I have not looked at Hive software, but often there is anti legionnaires software built in which will every so often heat the water to over 65°C. I had it with Nest, could not work out why when nothing set to run, central heating boiler was on, found it could be disabled and that's what I did, it seems this is quite common.
    • Thanks Thanks x 1
  6. Martin Cannon
    Martin Cannon
    22 Oct 2019
    4
    Thanks Received:
    Country:
    Good evening all.
    So it is a;
    Y Plan.
    Yes the is a cylinder thermostat.
    Brand new 3 way valve.
    Fully pumped.
    Full story, summer time, hot water working fine, 4 weeks ago tried the heating, would only come on when the HW was off, hence new 3 way valve. Still the same problem, so thought programmer, bought a Hive Active 2, fitted and here i am asking for help............ CH working fantastic, HW working but not as i think it should and or was. If it should work like this with a Hive, please let me know!!!!!!!
    Legionnaires, i will ask Hive.
    Water temp at the tap, really very hot.
    Martin
  7. Sponsored Links
  8. Martin Cannon
    Martin Cannon
    22 Oct 2019
    4
    Thanks Received:
    Country:
    Sorry Boiler is a Baxi Solo 18 HE.
  9. ericmark
    ericmark
    27 Jan 2008
    17,466
    Thanks Received:
    1,617
    Country:
    Y plan default is hot water, if the white wire is powered then it goes mid way, and if white and grey are powered it goes all the way and stops water to DHW. mid-position-valve.jpg So if you lose connection to grey then can't turn DHW off. This shows how it works.
  10. Martin Cannon
    Martin Cannon
    22 Oct 2019
    4
    Thanks Received:
    Country:
    So tomorrow I will check and make sure that I have not screwed on to the insulation of the wires and not just that they are in the correct position.
  11. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    Have you actually measured the temperature of the water at the tap? It should be around 60c.
  12. wwwebber
    wwwebber
    5 May 2004
    432
    Thanks Received:
    24
    Country:
    Hive doesn't control your hot water temp - it just schedules when your boiler can heat it.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
