Increase heat of hot water/water pressure
B
BillEmm
Hello,
I have recently moved into a new place and the temperature of the shower and the water pressure are quite poor, I have taken pictures of the boiler (attached), I was wondering if anybody might know how I can sort this out myself?
When I turn the red knob in the first picture, the boiler makes a hissing noise. any help would be greatly appreciated, I cannot afford for a plumbing/heating engineer to come and have a look at it
Boiler is Kingspan Albion AUD180 UltraSteel
Thank you in advance
https://ibb.co/56ndXBc
https://ibb.co/mzvvwsP
https://ibb.co/YkNmSQ8
56ndXBc
YkNmSQ8
mzvvwsP
Stop touching that, it is safety device and shouldnt be touched, That is not a boiler it is an unvented Hot water Cylinder
Thanks, do you have any wisdom regarding how I can increase the pressure of my shower? It runs fine for a minute or two and then slows right down/cools right down
Unfortunately, as it's an unvented cylinder you have to pay someone to come in a look at it. It needs to be a qualified engineer that works on it.
2 items on the cylinder need checked to see if they are impacting on the pressure side of things. The temperature side of things is another area but that needs whatever warms the cylinder to be looked at - what needs looked at depends on whether it's a direct (electrically heated) or indirect (boiler heated)
