- Joined
- 22 Dec 2015
- Messages
- 3
- Reaction score
- 0
- Country
Hey everyone.
I have Worcester 24i junior combi boiler (not the green star, the previous model) and live on 4th floor.
Whenever shower is used, it's impossible to have constant mix of warm water. There's a good pressure in hot and cold water taps separately, however when mixed the pressure drops. I'm having to fine tune the shower to a good temperature, but then after 2-3 min it gets cold (boiler stops heating it due to low HW flow I assume) so I have to full blast the hot water tap for hot water to come through, when it does (1-2 min later) I have to turn it down as not to burn myself, shower for 2-3 min, but then it gets cold again so I open the HW tap more and wait for it to come through and the process begins all over. Story of my life.
Water doesn't stop heating if it's mixed on too hot, but when it's at a good temperature it gets cold, due to low water flow.
This is due to low cold water pressure I assume?
I google quite a bit and am planning to install Salamander Home Boost pump, it's expensive, so I wanted to see what you experts advice before I make a mistake.
Many thanks for any advice.
