- Joined
- 27 Jan 2008
- Messages
- 27,753
- Reaction score
- 3,364
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I want to control the temperature of two rooms independently a bedroom and living room although there is a hall, wet room and kitchen these can really take care of them selves if the boiler runs when either of the two main rooms need heat.
I really need double pole thermostats one pole for radiator the other for the boiler “JG Speedfit JGPRTE Programmable Room Thermostat 240V” seems to fit the bill but can’t find a wiring diagram to find if single or double pole.
The “JG Speedfit Actuator Valve 240V” looks the part and looks as if it would clip onto an existing TRV but again description is rather vague.
With two sets of contacts on a thermostat one can open the valve and the other fire up the boiler. The contacts to fire up boiler on both thermostats would be in parallel. Theory is easy it is practice is the hard bit as info is so restricted on the products.
Two “Horstmann DRT2 Programmable Digital Room Thermostat” in each room or a relay would do the same as a double pole thermostat the relay would seem best option but then one has a problem of where to mount the relay.
So any ideas of suitable products? Once fitted I hope I will never need to touch them, however I would still want something that in an emergency any good electrician can repair.
