Indisit washing machine leaking from outer drum
6 Oct 2010
The machine appears to be leaking at the rear from a plate with electrical connections, attached to the outer drum.
Is this an easy fix, worth repairing?
Suspect it is a gasket fail for heating element.
Model is WM12X
That is definitely the heating element. Has it been replaced before? - the black tape is rather untidy and not what you would expect from a factory installation.
The single nut in the centre holds it in place - tightening it will expand the rubber seal and may stop the leak.
If not, loosen the nut and the element will pull out. Should then be obvious where the leak is.
The machine came with a property we are refurbing and had clearly been leaking for some time.
Once removed the area behind was saturated, however due to the floor being tiled up to the plinth and the floor behind being lower, there was no water obvious in the room. It's a pretty poor diy job, kitchen spurred off ring. So I would not be surprised if the machine had also been repaired poorly.
Nothing wrong with diy, as long as it is done correctly. Thank you for the advice. I will investigate and see what is needed.
:D
Thank you flameport.
The bolt was not on tight at all.
Tightened several turns by hand with screwdriver bolt attachment.
No leak!
