Induction hob in cooker outlet plate
23 Jan 2003
Hi advice please
Photo 1 shows the original cabling to an electric oven
Photo 2 shows an induction hob added
Is this acceptable with both working off a single cooker switch and a 32A breaker?
I know part of the induction hob wiring will be outside the outlet plate but it will be inaccessible behind the oven.
No not acceptable, single insulation shouldn't be visible when the lid is put back on.
Looks like theres already 2 appliances connected, what are they and whats the combined kW rating of all 3?
Currently there is a single oven and grill (rating unknown) and a socket (unused and can be disconnected) so there will only be the 2 appliances. The induction hob is 7200kw.
I could clip the induction hob cable so the single insulation sits inside the cover.
Would this be acceptable?
What is the solution? If the cables are not coiled they wlll not fit under the plate cover
