Yes, it's very loosely sleeved. The light is only controlled by the single switch. In all likelihood the installation was originally completed when the house was built c. 1995. Not sure if that makes it more or less likely to have been botched
I fear that botching started in the year dot and will remain with us for evermore!Yes, it's very loosely sleeved. The light is only controlled by the single switch. In all likelihood the installation was originally completed when the house was built c. 1995. Not sure if that makes it more or less likely to have been botched
Glad that you have found at least an immediate solution!Although revealing a new level numpty-ism on my part, I'm pleased to report that this has turned out better than I had expected. At your prompting I went back into the switch to sort the errant earth wire, only to find that there WAS after all an earth block attached to the backplate of the switch. I'd been so busy trying to find it on the 'front plate' where the switch and terminals were located I'd completely overlooked it! .... So the earth wire has a proper home at last! ... That said, it does raise the spectre of why it had been arranged as it had in the first place, so I may still get a professional to run some checks.
BTW is it critical for live feed to be connected to Com and the light to either L1 or L2? Or can the live go into L1 or 2 and the light into Com?
You're welcome.Thank you John for that very clear explanation, if only the supplied instructions had been so clear.
As you have just been told, for 'one-way switching' (i.e. if only one switch controls the light), it makes no difference. If it were a wall switch, rather than a pull one, the choice between L1 and L2 would determine 'which way up' the switch worked (i.e. whether 'up=off' or 'up=on'). Some people work to a convention of always connecting the live feed to COM - which is, of course, the option that could have caused a bang when you had the earth connected to the switch!BTW is it critical for live feed to be connected to Com and the light to either L1 or L2? Or can the live go into L1 or 2 and the light into Com?
Ah - you have a point there, at least in the case of a pull switch for a lightI don't think a pull switch will have a back-box.
Kind Regards, John
Putting Live into L1 and Switched Live into COM has the minor advantage that the un-used L2 terminal does not become live when the switch is OFF ( but this could confuse the average house basher aka cable installler )For 1 way switching it doesnt matter.
Indeed - that is, of course, the very point I explained in detail to the OP. If the 'earth wire' really is an earth, the only reason why there was no bang was that, by pure chance, the Live was not connected to COM. However, as I also said, I know that some deliberately adopt the convention of connecting permanent live to COM.Putting Live into L1 and Switched Live into COM has the minor advantage that the un-used L2 terminal does not become live when the switch is OFF ( but this could confuse the average house basher aka cable installler )
