I am aware of a "need" to install bathroom extractors, however not sure where the "need" comes from in the kitchen? I have never been a scheme member, so I don't know what "compliance" covers? The building regulations as split into parts, Part F - Ventilation, Part P - Electrics, Part J - Combustion appliances and fuel storage systems, finally Part L - Conservation of fuel and power. All these have a bearing on fitting an extractor fan.
So where gas is burnt you need to remove the fumes, (part f) and also you do not want in doing so to draw in fumes from some thing else (part j) and pump hot air in and clearly cold air will replace it unless a heat exchanger is used (part l) and the electrics used must be safe (part p).
So bathroom easy, all down to if windows open or not and that decides is simply from lights, or a PIR or a push button, and I am sure most tradesmen could do it, but since likely a special location likely needs a scheme member in other words an electrician.
With no gas kitchen is also easy, but with gas likely needs ducting to gas hob, with distances being strictly observed and also the ducting must not be a fire risk, Oh maybe I should have included Part B - fire safety.
So what we are asking is which trades have working knowledge of Parts B, F, J, L and P? Plus the skills to use core drills and fit roof vents. The most likely jack of all trades is the electrician however it is common to sub contract, so you could employ the local kitchen fitters who in turn sub contractor to roofer and builder and electrician. So in real terms take your pin and stick it in yellow pages it really does not matter who is the major contractor they will sub contract as required.
