Maybe.I was going for a ventaxia lo carbon which i thought operated by itself when it detected humidity?
It's on the shelf, next to the Observer Book Of Unicorns and underneath The Margaret Thatcher Prize for Tractor Collective Productivity Excellence.Where is this rule regarding whether or not the fan may be wired to come on with the light?
That is all true. However, as I implied, there could have been (but presumably isn't) a requirement that, in the absence of an openable window, not only must a fan be fitted (to a new build etc.) but, as fitted, it would automatically come on when the light was switched on (with maybe addition manual and/or humidistat controls) - so that it would at least come on 'sometimes'.Presumably, that means that, without a window, a fan will be in the design and fitted. That has to be the end of the matter. There can be no legal or other control over how the inhabitants connect or reconnect the fan, nor whether they ever switch it on.
And the point of all that "it isn't like this but it could have been" was what, exactly?That is all true. However, as I implied, there could have been (but presumably isn't) a requirement that, in the absence of an openable window, not only must a fan be fitted (to a new build etc.) but, as fitted, it would automatically come on when the light was switched on (with maybe addition manual and/or humidistat controls) - so that it would at least come on 'sometimes'.
After the house had been built, the owner could, of course, remove the wiring link to the light but, if the fan had been required at the time it was installed, that presumably would represent a non-compliance (to be picked up on subsequent EICRs etc.
However, there is (to the best of my knowledge) no such requirement, so the above is all about "how it could have been".
Kind Regards, John
The point was to indicate that EFLI was not really correct when he wrote (my emphasis):And the point of all that "it isn't like this but it could have been" was what, exactly?
I was pointing out that there can be control over how the inhabitants connect or reconnect the fan (compliantly), which would be the case if there were, for example, a requirement for the fan to come on with the lights (and maybe also with some other controls).EFLimpudence said:There can be no legal or other control over how the inhabitants connect or reconnect the fan, nor whether they ever switch it on.
That analogy is totally different from the situation I was talking about.But there isn't. If your aunt has balls she can be called your uncle. But she hasn't, and therefore she can't be.
Approved Document F said:Controls
Intermittent extract
May be operated manually and/or automatically by a sensor (e.g. humidity, occupancy/usage, pollutant release). Humidity controls should not be used for sanitary accommodation as odour is the main pollutant.
In kitchens, any automatic control must provide sufficient flow during cooking with fossil fuel (e.g. gas) to avoid build-up of combustion products.
Any automatic control should have a manual override to allow the occupant to turn the extract on.
In a room with no openable window (i.e. an internal room) an intermittent extract fan should have a 15 minute overrun. In rooms with no natural light, the fans could be controlled by the operation of the main room light switch
<stuff from a document which imposes no requirements>
No, it doesn't say that there must be.So as said with no window can be turned on with light, and with opening window it is not required anyway but with non opening window there must be a way to turn it on independent to the light switch,
No, it does not say that there needs to be.all other automatic controls also need an override to manually turn it on,
Nothing to do with them.however the LABC insisted as the wet room was on the ground floor so leaving a window open means some one can look into the room and is a security issue if left open.
No, it doesn't mean that.I think "In rooms with no natural light, the fans could be controlled by the operation of the main room light switch" is a odd way to put it, as it means in rooms with natural light it can not be controlled by operation of the main room light switch,
No, it doesn't have to.and that is incorrect it can be controlled by light switch but must also have another method to manually switch it on.
Whilst that is literally true, if one had a momentary action 'over-ride' switch/button in parallel with the (single pole) light switch, the light would only come on momentarily when one 'pressed the over-ride'.... there must be a way to turn it on independent to the light switch, all other automatic controls also need an override to manually turn it on, but that is easy, however with lights it means using a double pole light switch so pressing the override does not also switch on the lights.
Kind Regards, John
Is that not what I said?I simply flick the lights on and off,
